Fork spring help
Old Nov 25, 2009 | 08:21 AM
mhaisten's Avatar
Wrench Bender
Fork spring help
I need to change my fork springs. How do I tell what weight to get? I weigh 250 lbs. May want to take the wife for a ride every now and then (135ish).
Old Nov 25, 2009 | 08:32 AM
AngryOlaf's Avatar
Race Tech has a calculator to answer your question...
http://old.racetech.com/evalving/Spr...pringType=Fork
Old Nov 25, 2009 | 08:34 AM
comedo's Avatar
One source of information about spring rates is www.race-tech.com.
Old Nov 25, 2009 | 09:45 AM
franz125's Avatar
franz125 is on a distinguished road
Try Sonicspring,better calculator.More accurate.
Old Nov 25, 2009 | 01:20 PM
cameron's Avatar
great links guys thanks
Old Nov 25, 2009 | 02:49 PM
Greg always asks what your weight is while wearing full gear - what ever you have. The suspension on the bike is very sensitive and at its very best when it's properly tuned. 15 pounds DOES make a difference. A good adjustable shock is an important part of this package and absolutely required for two-up riding.
Old Nov 25, 2009 | 05:03 PM
JamieDaugherty's Avatar
I suggest 1.0kg/mm springs for your weight. I hope that helps!
Old Nov 26, 2009 | 07:24 AM
FWIW - Here is a little chart showing rider weight vs. fork spring rate. Please note that the weights shown are without gear i.e. in street clothes:
VTR1000F Fork Spring Rate Chart
115-150lb = 0.80kg/mm
150-180lb = 0.85kg/mm
180-215lb = 0.90kg/mm
215-250lb = 0.95kg/mm
250-300lb = 1.0kg/mm
As you can see, mhaisten is on the bubble between 0.95 and 1.0. For these cases I round up.
Old Nov 27, 2009 | 08:21 PM
Don't forget to account for weight lost from the bike from aftermarket stuff. Hell, you can lose 15# just from slip-ons, of course that's mostly in the rear though.
Spring rate also depends how you ride. If you're doing a lot of track days and braking hard then you'll want to go up in rate .05 to .10 kg/mm. For just street the table Jamie posted is perfect.
Old Nov 28, 2009 | 07:30 AM
That's a good point. I should have put the caveat on that table that the rates are for street riders. These are reasons why it helps to get with a suspension tuner who can help sort out these kinds of variables for you.
Old Sep 7, 2015 | 05:04 PM
snowdirt's Avatar
snowdirt is on a distinguished road
Hi everyone. New to forum today.
Got 8,000 miles on VTR I purchased one year ago. Immediately (within 500 miles), largely based on this thread, I chose "180-215lb = 0.90kg/mm" springs to replace the stock jokes. (( I weight 178 lbs without gear )). As soon as I let the VTR down off the jack I knew immediately the springs were too soft. They are definitely preloaded correctly as I was precise with the required cuts ( also I can only tolerate the preload adjuster about halfway in. After that the tire gives too much rumble feeback on the road. a good indicator that preload is correct). So, last week, after 7,500 miles I went with the next spring "215-250lb = 0.95kg/mm". The feel of this spring (also a racetech) is a huge improvement. Bike actually has a smoother ride too cause I run a bit less preload. Its much less prone to that dive/knife when doing a quick flip into a turn. Its also less prone to wallow and wag a bit when encountering minor asphalt rolls in high G banked turns. I'm actually kind of elderly (just a few months shy of 65) but have quite a bit of motocross and supermotard experience but I really don't think that matters that much. The .90 KG is just a bad choice for a 178 lb VTR rider who occasionally scrapes the pegs on the street. Just some feedback for future fork spring swappers. Oh, and it has stock fork valving. Later...
GlockPointer
Dec 20, 2011 07:29 PM
Bearshawk
Oct 3, 2011 04:21 AM
roisman
Mar 25, 2008 10:43 AM
speedkelly@aol.com
Jul 18, 2007 06:00 PM
filter_jam
Apr 12, 2007 02:18 PM
