Fork oil?
I was changing oem fork springs to 1.0 kg springs,what oil stiffness you recommend?
That would depend on if you are leaving the valving stock or are you revalving it for the new springs. If you revalve use 5wt. if not either 7.5wt or 10wt can be used as a "band aid" fix.
Thanks!
