First Ride - Not Charging
Old Feb 22, 2010 | 08:48 AM
psyclown's Avatar
psyclown is on a distinguished road
Hey all, the snow cleared up enought to take the SH out for a short spin. Wow. This thing pulls hard from any rpm, awesome. Unfortunatly, this is the first time i have had this thing running with out a jump box and i don't think I'm getting anything out of my charging system.
I haven't looked into the cause yet, but I have notice that the r/r on this thing is finned. If I remember correctly, I have read on here that the r/r on the stock SH is not finned. Am I correct in assuming that the PO replace it with one from another bike??
Old Feb 22, 2010 | 08:54 AM
nothing's Avatar
ride it out
yes you can assume that. it's either an upgraded one, or one from an r6/r1 yamaha.
HTH
http://www.electrosport.com/technica...ng-diagram.pdf
Old Feb 22, 2010 | 09:00 AM
NCDave's Avatar
Yep. Good assumption. Any idea how long the R/R has been on it?
It's also possible that cells on the battery are bad and not holding a charge. Most of the auto parts stores can also load test motorcycle batteries, so have that checked first.
One other thing to check...I have been having starting problems over the winter with the bike being cold. I checked the specifics on the battery that was in it and discovered that it's only rated for 180 CCA. Obviously the previous owner did not pay attention to the requirements since it needs 210 CCA to turn over properly.
Old Feb 22, 2010 | 09:35 AM
psyclown's Avatar
thanks for the tips, yesterday I check the voltage of the battery while running and at 4k or so and it doesn't register anythikng over about 12.5. So, not getting anything
Old Feb 22, 2010 | 09:59 AM
It all depends on what year the bike is as to weather the stock R\R has fins or not but if you are only getting 12.5 VDC then either the R\R is bad or the stator is shot. I would check the R\R as it is the most likely cause.
Old Feb 22, 2010 | 10:54 AM
psyclown's Avatar
Sorry, I thought I said it's a 99. I've got my fingers crossed that it's a connection problem.
Old Feb 22, 2010 | 12:05 PM
Well then if it's finned it's been replaced. Check the connector to see if it burned and clean your grounds and try the test again.
Old Feb 22, 2010 | 03:13 PM
psyclown's Avatar
The connector is burnt at one of the prongs. Does that indicate a fried r/r?
Old Feb 22, 2010 | 03:49 PM
That could have happened when the first one went. Make sure the contacts are clean and retest the system
Old Feb 22, 2010 | 04:05 PM
psyclown's Avatar
Anyone have any tips for cleaning these little *** connectors?
Old Feb 22, 2010 | 04:30 PM
nothing's Avatar
ride it out
steel wool and a lot of patience. solvents will work (i've heard of using baking soda and then water) but you'll still have to scrub a bit. Make sure everything is disconnected haha, and use some dielectric grease you can get at autozone or whatever to prevent future problems
Old Feb 23, 2010 | 10:00 AM
psyclown's Avatar
Yea i fidured that much. I was jsut hoping someone had a revolutionary idea for cleaning em easier.
Old Feb 24, 2010 | 12:39 PM
Try a flat jewelers file with a strip of 1000 grit wrapped around it for the male terminals. The same 1000 grit folded several times about the same size as the spade works on the female terminals.
Old Feb 25, 2010 | 05:29 PM
psyclown's Avatar
Anyone care to explain section "c" of nothing's link above in plain English? I'm down to the rr and I think I may be interpreting wrong.
Old Feb 26, 2010 | 03:16 PM
psyclown's Avatar
I guess not. Anyway, my rr looks like the one selling on ebay for 75 bones. I assume it's anupdated version and not the r1/r6
Old Feb 26, 2010 | 04:07 PM
Little_Horse's Avatar
2nd mouse gets the cheese
So other then not holding a charge were there any other symptoms?
Like your gauges stop working... or eventual failure of the bike.
I personally think we are over thinking things and should start by ruling out the battery. On my hawk it has never registered more then 12.5 volts at the battery when running and I don't have any charging issues.
sweetriden76
Sep 22, 2009 05:20 PM
sittinxsidewayz
Jul 14, 2009 10:56 AM
RI-redhawk
Apr 24, 2009 11:42 AM
98 checkered ghost
Mar 28, 2008 05:56 AM
98VTR
Jun 9, 2006 10:57 AM
