Feedback thru the Handlebars
It is hard to explain but my front end at certain speeds 60-70mph gives a strange sensation thru the clip ons, I know Twins vibrate but this is not from the engine as i still feel it when I pull the clutch in at the higher speeds I know one of my rotors is slightly warped so I pull in the clutch and apply a little front brake and it is still kind of there.... any ideas?
what happens when you brake from that speed?
Try re-balancing the front wheel.....;)
How about the tire condition?
When was the last time you changed the oil in the front forks? |
fork oil has been changed, tires like new, HHMMMM I will check the wheel balance though....when I brake the sensation does not really go away but I am just applying enough brake to have the pads make contact with the rotors
