SuperHawk Forum
-   -   F4i rear shock question (https://www.superhawkforum.com/forums/technical-discussion-28/f4i-rear-shock-question-32187/)
scooter72 Jun 13, 2014 12:31 PM
I was thinking about doing the f4i rear shock on my bike, since installing the 1000rr front end has really brought out how lousy that rear shock is, but funds are tight with building a house and a wife telling me that I cant spend any more money on the bike...so as much as i'd love to, the DMR f4i shock is out of my price range as of now.
My question is, has anyone installed an f4i shock on the VTR with no changes to springs or valving? Making the shock adapter isn't a problem, that is a case of beer to my machinist buddy plus a bushing. Just don't know if it'll be worthwhile in stock form, it has to be better than the VTR shock due to the greater adjustability in damping though. Once money starts flowing again, I will send it out for tuning and valving, just want something cost effective in the meantime.
jefejrs Jun 13, 2014 04:45 PM
This...
Daugherty Motorsports - Motorcycle Suspension Performance and Modification
CruxGNZ Jun 13, 2014 05:22 PM
Someone sucks at reading.
EDIT: No, it's not you scoots.
scooter72 Jun 13, 2014 09:03 PM
Too funny....I think I'm gonna pick up a shock and mill up an adapter for the lower mount regardless and see how it works....if it doesn't work right, the stocker will go back in until the money comes through to send it to Jamie for a respring and valving. Like I said earlier, it can be any worse than the stock VTR shock. At least with the adapter made up already that should save me some cost on the rebuild from him.
NZSpokes Jun 14, 2014 01:11 AM
My call is it may be better but not worse. And you get some compression adjustment.
xeris Jun 14, 2014 06:11 AM
Does the f4I use a shock linkage similar to the VTR?
NZSpokes Jun 14, 2014 01:28 PM
Yes.
xeris Jun 14, 2014 04:05 PM
I read in another thread here that the f4i stock shock spring is too soft for the SH.
NZSpokes Jun 14, 2014 05:42 PM
One would have thought you would swap the spring from the Hawk shock to the F4i shock.
jscobey Jun 14, 2014 06:07 PM
IIRC they are different lengths. plus im not 100% sure but i think the spring diameter on the hawk is different at the top and bottom.
both of those facts could be totally wrong tho...
NZSpokes Jun 14, 2014 08:19 PM
Thinking about it your right. My Bad.
I remembered I swapped mine from my 919 to my hawk. But that was onto a Ohlins now I think about it.
