SuperHawk Forum
-   -   Exhaust studs - snapped (https://www.superhawkforum.com/forums/technical-discussion-28/exhaust-studs-snapped-22792/)
residentg 06-05-2010 02:49 PM
Fixing up the 1999 parts bucket. The front exhaust studs snapped on me. Honda does not list a seperate part number for the studs. Does anyone have any experience with these? Are they screw in or pressed into the cylinder? Fortunately about 1/2" of the studs are still exposed. BTW no issues with the rear studs. Thanks. JB
Hawkrider 06-05-2010 02:59 PM
90035-MZ1-000
$4 at ronayers.com
They should thread in. Some PB Blaster and heating the cylinder head around the bolt should help.
residentg 06-05-2010 03:18 PM
wow thanks - servicehonda did not show them on the fiche - this is great! JB
mikstr 06-05-2010 05:05 PM
They definitely screw in as I had one that was problematic as it wasn't ever fully seated (fixed it with some hi-temp Loctite).
VTRsurfer 06-05-2010 08:12 PM
Broken exhaust studs always suck. Hopefully you were using a torque wrench, or they broke taking the nuts off. Glad you at least have something to work with. Greg's suggestion of using PB Blaster is a good one. Great product.
Hawkrider 06-05-2010 10:33 PM
They are in the fiche, #13 on the cylinder heads.
residentg 06-06-2010 02:55 AM
How the f did I miss that! Thanks Greg.
JB
