SuperHawk Forum
-   -   Electrical Part Help (https://www.superhawkforum.com/forums/technical-discussion-28/electrical-part-help-35823/)
vtwinfun Jun 30, 2021 08:26 AM
Had a pin on the connector to Ignition Control Module break, well corrode. I’ve called a couple different Honda dealers and they have had no luck finding the pin. I have seen some that look like the same pin but are larger. Any of you happen to have a Part # or an idea of who to contact for one? Thanks.
Wolverine Jun 30, 2021 04:48 PM
So is this the ICM or the plug connector? That's a tough one, doubt you'll find an available part to buy if it is what I'm imagining it to be. Might need to get a used piece and perform surgery.
xeris Jun 30, 2021 07:07 PM
Take a look here Motorcycle Connectors
vtwinfun Jun 30, 2021 07:18 PM
https://cimg8.ibsrv.net/gimg/www.sup...cff5d37d9.jpeg
The pins located in the connector body it’s self. I knew this was a long shot, just thought someone may have been here before.
vtwinfun Jun 30, 2021 07:21 PM
brilliant! This should help me get started in the right direction! Thanks a ton!
