Dyno results
I have just had my bike dyno-tuned today,.. after fitting low restriction mufflers and a K&N air filter. Its STD. with no other modification. It apparently was running very lean.
They also removed the restricter plates from the inlet ports, at the same time as replacing the needles and jets. It is running on 91 octane unleaded fuel and returning .. 105 hp .. up from 95 hp .. and stronger in the mid-range,.. kewl. :lol: I was just wondering if that is about normal for this engine ? |
Re: Dyno results
wow... impressive results!
how does your torque curve look like? did you gain anything in 2-5k rpm?? if you can scan and post the before/after curves, that would be great! |
Re: Dyno results
Sorry,.. I don't have a scanner... :cry:
I did not get the print-out on torque,.. mm.. :roll: .. I better go back and see if that is still available. When I took it out for a quick squirt today,.. it sure did feel good. It wanted to pick the front wheel up in the lower gears. |
