dual output stand alone ignition
Hey folks, I need an ignition for a project bike. Its a parallel twin that is getting a rephase to a 90 degree crank. I need a pickup, a trigger wheel, and a "box" with an ignition curve that would give me a decent start up advance with a max between 45-50 degrees. Max rpm around 12k. Programmable or not. Preferably capable of batteryless. Right now, only option that I am finding right now is $575.
An Ignitech programmable box should do the trick for significantly less $$$$
thanks, I am checking out the goodies right now.
| All times are GMT -7. The time now is 11:36 PM. |
