SuperHawk Forum
-   -   draining coolant (https://www.superhawkforum.com/forums/technical-discussion-28/draining-coolant-12752/)
05xman Sep 22, 2007 04:26 AM
draining coolant
Is there a petcock or a drain some where or should I just pull the lower radiator hoses?
vtrj Sep 22, 2007 04:30 AM
On the front of the front cylinder right behind the coolant hose that connects the two radiators, small ten mil bolt with a brass washer.
05xman Sep 22, 2007 04:33 AM
thank you, now after I finish the coffee I can go work on the bike.
05xman Sep 22, 2007 03:11 PM
so I pulled that 10mm bolt and like 3 drops of coolant came out.
loserbaby Sep 22, 2007 03:16 PM
did you remove the radiator cap?
05xman Sep 22, 2007 06:40 PM
doh didn't even see it hiding up there under the right side. but she is all back together with new plugs, air filter and all new fluids.
