SuperHawk Forum
-   -   Down On Power - CCT Issue? (https://www.superhawkforum.com/forums/technical-discussion-28/down-power-cct-issue-34517/)
RonVTR May 10, 2017 08:01 AM
Hi, I searched and read many CCT related articles on this forum however didn't find anything that specifically referenced my symptoms... Maybe someone here can confirm if this is a CCT related issue?
While down shifting through the gears - The Superhawk's Stain-tunes sound so good doing this - I felt a little 'hick up'. After that moment, it was noticeably down on power. It starts and runs but feels more like a 750cc VTR. After failing to find anything wrong, I decided to take it into the dealer.
Dealer did a compression test and leak down test. Here are the results:
Leak Down: F = 15%, R = 20%
Compression: F = 115, R = 120
My VTR is a 1998 with 32,000 miles. It has the original CCTs.
Thanks
Ron
Wicky May 10, 2017 09:15 AM
airfilter? hoses esp vacuum firmly in the right place with no holes/spilts? - same for the petcock diaphragm. Carbs need cleaning - gummed up? old fuel?
Plugs?, plug caps firmly on?
http://www.vtr1000.org/phpBB3/images/smilies/eek.gif
CCT failure is binary - either they work or they don't - with the bike producing the sound of a cement mixer full of metalic junk...
Wolverine May 10, 2017 09:34 AM
Are you mechanically inclined enough to pull the cam covers and check timing?
This is the next step I'd take.
RonVTR May 11, 2017 07:38 AM
Just an update... I asked the dealer to check engine timing yesterday.
Wolverine May 11, 2017 03:08 PM
Get them some manual cct's and never worry about it again! You're on borrowed time.
xeris May 13, 2017 08:16 AM
There are good mechanics and not so good mechanics. I hope your luck falls to the former.
Let "borrowed time" guide you decisions.
