Dimensions of engine mounts
What would be a good way to get dimensions for the engine mounting points?
One idea I have in mind is to remove the engine from the frame, prop it up with blocks of wood to where it would be if in a frame, then mount 2 planks of wood on both sides and just eyeball it from there. Any suggestions? |
| All times are GMT -7. The time now is 08:06 AM. |
