Diesel Superhawk
I have tried to figure this out myself but I cannot seem to locate the source of this noise. It sounds like diesel engine and the noise is coming from the right crankcase cover. I thought it was a defective clutch basket but the one I put on didnt make a difference. It kinda sounds like something is knocking in there. I put it to you guys since you've probably heard it all. Is that the dreaded CCT noise? NEED HELP with this I'm goin nutz!!
Does the noise change when you pull in the clutch?
Darn, I was hoping this was about someone actually making a Diesel SH. That'd be sweet!
No the noise does not change if you pull the clutch. Did the old screwdriver to the ear and its loud at that cover. Only thing there is the clutch right? Oddly when I took the clutch basket off the area behind the basket looked torn up. I cant tell where it came from but it looks like the back of the basket was rubbing against it. No damage on the back of the basket though. Thats what i get for buying a used bike.
I messed up the ignition advance unit and I believe it drives the water pump - a black component iirc (to the right of the clutch basket and I believe its spring loaded and that was my problem, it moved - this was over 2 years ago so memory may be off a little) when I installed the factory pro detent arm/spring and it had a noticeable knock after that. I pulled it apart again and got it back to where it should have been and was fine ever since... could be someone played in there at one time and didn't get it back together right.
Originally Posted by lazn
(Post 64488)
Better pull the cover and check.....
Did you really find carnage behind the clutch and not figure out what caused it and put it back together again? All due respect etc.... |
Got me too! LOL
Sorry to hijack. This isn’t a SH, but it is diesel.http://www.hydraulicinnovations.com/more%20pictures.htm:cool:
Originally Posted by Gregw
(Post 64552)
Yeah, there was a race mod when the bike first came out that removed the quieting gear, the spring loaded one on top of the actual gear over the timing pawl. It has springs in it that connect it to the other one. Check to see that it's there and that it works properly.
I know what ur thinkin Redman and its not what u think. I got this bike on the side from a dealer...aka no paper trail. I knew whowever had it beat it up some but it didnt look like it was trashed. A few cosmetics aside and it looks good. The noise started shortly after getting it. I purchased a clutch basket from some poor dudes wrecked hawk. When I put it on last week I noticed the rub marks behind the basket. I can only guess what happened there but here goes.
1. the bearings on the clutch were replaced before I got to it and did my own repair. 2. the oil pump chain broke and continued to spin whiplashing any metal piece in the area. Its hard to tell what happened and i'll take some pics and post them to see what you guys think. |
Is that under the ignition rotor? I wanted to replace that and get the factory pro but there back ordered till october. |
(Post 64562)
Naw man, this is the cool one: http://www.dieselmotorcycle.co.uk/
Originally Posted by gimpy
(Post 64571)
