Deglazing brake discs
Has anyone have an opinion (that's a laugh) on using a wire cup (soft) on an angle grinder or bench grinder to de-glaze a disc? I have done it on auto discs with good results.
You can laugh @ my opinion.... Flappy disc & brake clean.
Sparky Type 27 Flat Flap Disc - CERAMIC - Specifically for Stainless Steel Applications at sparkyabrasives.com http://www.harborfreight.com/media/c...image_8090.jpg |
I use scotch roloc discs in an angle die grinder and rubbing alcohol as a lube/solvent, finish with brake clean and a rag
Originally Posted by Fastguy59
(Post 397633)
Might want to consider the use of rubbing alcohol,, the flash point is really low depending on what % it is. very common 90% Isopropyl Alcohol has a flash point of only 54deg F 70% is only 77deg F and both vaporize making an even more combustible fuel at very low points. |
(Post 397643)
Same here but use brake clean only..
Medium grit on the Roloc? The maroon colored?
Originally Posted by xeris
(Post 397648)
(Post 397658)
For me yes the maroon rolocs work fine! Erik what say you?
Thanks for the replies.
Because I won't work the tool very hard, longevity is not an issue, and as much as it pains me, I purchased a small angle die grinder from china harbor. Will have at it in a couple of days. |
1 Attachment(s)
I have the roloc system but prefer this if you want to remove all residual brake pad material.
4"x1-1/4" Paint & Rust Stripper Disc - Painting Tools - by Greschlers Hardware |
(Post 397764)
(Post 397764)
4"x1-1/4" Paint & Rust Stripper Disc - Painting Tools - by Greschlers Hardware http://3mcollision.com/3m-roloc-brak...pack-1410.html But if I ever run out of the 3M conditioning disks, I now have a reccomended option I might find locally.. Thanks |
A side effect/result of deglazing is that it puts a non-directional finish on your rotors which will bed your new pads into the existing disc in half the time... Win, win!
The brake pad conditioning disc are designed to used in conjunction with a brake lathe turning at a constant speed while the tech applies one pass to the outside then a slightly overlapping pass to the inside of each side of the rotor. Doing this with the rotor static and moving the grinding medium, makes keeping the disc flat to the rotor very, very hard. I have tons of these discs on my drawer, but changed to the roloc maroon after measuring disc irregularities with the 120 grit disc used with the rotor being static...
(Post 397772)
1 Attachment(s)
Oh, and to finish the job I got one of these.
The ball hone ads a multidirectional etch to the disc. Just like a new one from the factory. |
