Crankcase bolt torque?
I will be putting my crankcase back together soon and it seems that the manual has overlooked the torque specs on some, I mean most, of the bolts. And yes, it's the Honda manual.
There are a total of 28 bolts fastening the two halves together. It only gives specs for the 10mm ones. Of which there are only 9 of them. There are a bunch of 8mm and 6mm bolts both top and bottom side that I cannot figure out. 29 and 31 lb/ft is what the 10mm bolts call for. That seems like too much for the others, especially the little 6's. Am I missing something?... I was thinking about going with generic specs for their size but was curious what some of you have done. Please advise |
I do not have my Haynes manual near me to check for you (it is in storage 200km away), but I can assure you that each size has a different torque setting.
So wait until you can find out what they are. A few guys on here will be able to tell you, as a few have done rebuilds, and will have the specs handy. |
1 Attachment(s)
Bolt shank diameters, not bolt head wrench size. There is a similar table on page 1-11 of the service manual.
Attachment 27440 |
Originally Posted by residentg
(Post 263537)
But my question is whether to use a chart like this to find the values or are there actual Honda specs floating around somewhere. I know plenty of people around here have had the cases apart. What torques did you guys go with? |
Page 1-11 in the Honda manual
Also 11-0
[quote=mboe794;263627]Obviously...quote]
Not to me, I've busted a couple. Just trying to help. JB |
Page 11-0 doesn't give me what I'm looking for. Only the 10mm bolts as I stated before. Maybe I have an older version of the manual or something.
I guess I will go with the standard torque for the 8 and 6mm bolts listed on page 1-11. Just seems odd that they are not labeled specifically in the crankcase section. There are a ton of other less important bolts around the bike with specific torque values. Thanks for the insight everyone. |
| All times are GMT -7. The time now is 05:53 AM. |
