SuperHawk Forum
-   -   COP Tach? (https://www.superhawkforum.com/forums/technical-discussion-28/cop-tach-35610/)
CaryDG May 17, 2020 07:48 PM
COP Tach?
Out of shear boredom, decided to do a little tuning and I realized now that I have Eric's superb COP setup so I can no longer use my Induction tach setup as there are no spark leads anymore. I'm setting my fuel screws using the idle Drop Method so I need a fairly accurate tach. Any ideas? (Hint, hint, Eric)
ACE VenTRa Dec 29, 2020 09:30 AM
This is a common issue in the import tuner world as well, I was thinking that there must be a vacuum tach out there somewhere...But out of curiosity, what is the setup you have now? If I see the schematic I'm sure I have an idea to make it work.
AV
CaryDG Dec 29, 2020 12:10 PM
Ace, thanks for the reply, but I now use my Digi-Sync. It works great! Best Sync tool I've used.
