coerce sprocket guard
Old Jul 2, 2010 | 10:18 AM
zubzero's Avatar
zubzero is on a distinguished road
So i bought this from ebay.uk and but it in my bike, everything went smoothly etc but the next day i tried to go for a ride... clutch....1gear on...release clutch...and nothing happens...bike wont move an inch!! I look at the clutch sylinder etc and it moves when i pulled the clutch, all though it moves about 1cm or so?
So when that happeden i take the coerce guard of and put the original on because i had to go for a ride, when all in original shape clutch works?? It releases good etc??? What the hell could do that???
below is the link for the guard...
http://cgi.ebay.co.uk/Coerce-Sprocke...item3a5c5313f7
Old Jul 2, 2010 | 10:29 AM
taskmasta's Avatar
Pew Pew...lasers
mine did the same thing at first. i didn't use the stock "plate". It is part number 4 here http://fiche.ronayers.com/Index.cfm/...VER_WATER_PUMP. once i used the plate with the coerce guard everything worked fine. I also flushed and replaced the brake fluid.
Old Jul 2, 2010 | 10:49 AM
zubzero's Avatar
Ty! I did the same mistake...will try again tomorrow with the plate on...thanks again for the tip!
Old Jul 2, 2010 | 08:56 PM
taskmasta's Avatar
Pew Pew...lasers
btw...i meant clutch fluid...same stuff though.
Old Jul 2, 2010 | 09:17 PM
While they do look pretty cool, I could never justify removing a magnesium part and replacing it with Aluminum.
Old Jul 4, 2010 | 09:34 AM
taskmasta's Avatar
Pew Pew...lasers
so did it work for you too?
Old Jul 4, 2010 | 11:51 AM
I still have the stock unit on mine as I loves my magnesium....
Old Jul 5, 2010 | 12:41 AM
zubzero's Avatar
Yep! Worked like a charm!! TY!
E.Marquez
Aug 19, 2014 01:30 AM
krongsak
May 5, 2013 10:49 AM
motormouth
Mar 5, 2012 03:31 PM
Scumbag
Mar 26, 2009 03:32 AM
Scumbag
May 6, 2007 10:46 AM
