coerce sprocket guard
So i bought this from ebay.uk and but it in my bike, everything went smoothly etc but the next day i tried to go for a ride... clutch....1gear on...release clutch...and nothing happens...bike wont move an inch!! I look at the clutch sylinder etc and it moves when i pulled the clutch, all though it moves about 1cm or so?
So when that happeden i take the coerce guard of and put the original on because i had to go for a ride, when all in original shape clutch works?? It releases good etc??? What the hell could do that??? below is the link for the guard... http://cgi.ebay.co.uk/Coerce-Sprocke...item3a5c5313f7 |
Originally Posted by zubzero
(Post 272261)
Originally Posted by taskmasta
(Post 272262)
mine did the same thing at first. i didn't use the stock "plate". It is part number 4 here http://fiche.ronayers.com/Index.cfm/...VER_WATER_PUMP. once i used the plate with the coerce guard everything worked fine. I also flushed and replaced the brake fluid.
btw...i meant clutch fluid...same stuff though.
While they do look pretty cool, I could never justify removing a magnesium part and replacing it with Aluminum.
so did it work for you too?
(Post 272494)
(Post 272494)
