SuperHawk Forum
-   -   clutch grabs high on lever (https://www.superhawkforum.com/forums/technical-discussion-28/clutch-grabs-high-lever-27757/)
toeknee19 Mar 10, 2012 11:32 AM
taking out my SH for the 1st time i notice the really high so i tried bleeding the slave and got the same results. Is it time to replace the clutch? Anybody have any luck with aftermark kits or should i go factory clutch setup?
saige Mar 10, 2012 11:36 AM
mine grabs pretty high too.seems normal to me.
if its all bleed properly,it should be good to go.
are you getting any slipping,grinding or hard shifts.
if not,it should be fine,once you get use to it,you wont even notice.
toeknee19 Mar 10, 2012 11:57 AM
no the bike doesn't slip, i guess i can live with a high grabbing clutch. thanks
Stevebis1 Mar 10, 2012 12:06 PM
Near the end is pretty standard for these. Same advice as saige, if it is not slipping or otherwise funky your probably good to go
7moore7 Mar 10, 2012 02:07 PM
+1 If you ride other bikes and then switch to this one, it seems to a little too far out at first.
Now try riding this one for awhile and go back to another bike ;)
meanhawk98 Mar 24, 2012 03:42 PM
a set of aftermarket adjustable levers cures that, i got shorty adjustable took care of that
RWhisen Mar 24, 2012 06:27 PM
That is one of the characteristics of this bike and is normal.
scottiemann Apr 3, 2012 04:26 AM
mine needs to be changed, slipping a little bit but otherwise fine... ive been beating on the factory one for the past 28k...
+1 on switching to another bike
I test road a repsol cbr1000rr with a slipper clutch... that was a strange experience
