Clutch cover bolts
I am having a difficult time finding out what length bolt goes in what hole on the clutch cover. I remember seeing a picture somewhere that showed, "Long bolt goes here, Short bolt goes here", but after searching this site for a half hour, I can't find it. The Manual doesn't show what bolt goes where either. I took the cover off to replace it, because the P.O. busted a nice hole in the side of it. He also broke one of the bolts off inside the engine, so I just can't go off of what the previous owner had in what hole. I have everything painted and ready to be installed with new stainless allen head bolts. Just need to know what bolts go in what hole.
https://www.superhawkforum.com/forum...ngine-2864.jpg |
That's the picture! Dude, you rock. Thanks!
Another way that almost always works is to just set each one in a hole. Then move them around until they all stick out about the same length. Usually they are within a couple mm's.
Originally Posted by mboe794
(Post 304723)
Whenever I pull something apart like this cover, I usually draw a picture on a piece of cardboard and poke the bolts through the spot that they are supposed to go. Actually, I took a picture of my alternator cover and inadvertently got just that in the picture below. https://www.superhawkforum.com/forum...inted-2863.jpg Now, here's something that is bothering me. I took the bolts out of the busted clutch cover that the P.O. had apparently installed. I out of habit, removed each bolt and poked them through the cardboard picture. Now, going off of the picture from the link provided above, the P.O. really screwed up where the long bolts were supposed to go. Could there be some spots where the P.O. drove the long bolts into where the short bolts were supposed to go and did some damage? Could he have torqued the bolt down and maybe drove the end of the bolt into a spot that it wasn't supposed to be in? Could there be any damage done to my engine from this nimrod? The engine was running when I bought it. It has good compression. I'm worried that something might be cracked or maybe he punched the end of the bolt into a coolant passage or something. |
The DPO could have done many things. Unfortunately, DPO's exist and most of the time we know them as "hobbyist" or "tinkerers". Usually a friend who doesnt have a clue about jack shit will let you know that this guy is pretty handy with the tools. To bad...
Originally Posted by CruxGNZ
(Post 304736)
You totally lost me there.
The only possible damage I could see is if too short of a bolt was used in a givin location, and then torqued with only a few threads fastening it. That could result in mangled threads. Too long of a bolt would just stop. It would take some serious torque to punch thought the other side of anything. And even then, I think these fairly small bolts would just snap off before that.
(Post 304741)
The cover is on and the correct bolts are in the correct holes. Thanks guys! |
My PO was a POS too... helps you learn more though. Drawing on the cardboard and putting the bolts in is a good idea- I'll have to use that in the future
Crux, it sounds like you achieved a 'zen-moto' moment there. Have you read Pirsig's book yet? You may be a candidate for readership. "Zen and the Art of Motorcycle Maintenance". Not a book about wrenching, or religion, rather a book about attitude and personal philosophy. Used bookstores, paperback for about a dollar. Grins, later.
Originally Posted by PUSHrod
(Post 304780)
