Clutch catches late
Hey guys,
Over the past few weeks, I have been having an issue where it feels like the clutch catches late when i am releasing it. I have used the clutch lever adjustment which helped a bit, but it seems to be getting worse. Is this signs of the clutch going bad or possibly something else? Thanks in advance!! |
yep, most likely going bad. you should check your fluid and perhaps bleed the system just to be sure everything is right down to the slave cylinder.
Cool, Thanks for the advice! I will let you know how that goes :D
