clutch adjustment
So my clutch does not engage till the lever is almost released. If I let it out to quick the bike jolts like it is slipping. Is there anyway to adjust the clutch where it engages at? Thanks for all the help.
Flush and bleed the lines,there might be air trapped in the system.
Thanks I will start with that. What is the best way to bleed it?
If you've got a mighty vac suck all the fluid out of the resivoir and replace it with fresh fluid. Then hook it to the bleeder on the slave cylinder, crack it and start sucking the fluid out. Keep an eye on the fluid at the top to make sure it doesn't empty the resivoir and just keep topping the resivoir off until the fluid coming out down below looks like fresh clean fluid.
If no mighty vac,will have to bleed out the same way you do the brakes.
I am not use to a cable clutch. All the Honda's I have owned have all been hydraulic. I am going to see if I can borrow my friends airbleeder. I have downloaded the repair manual and will look it over tonight. Thanks for all the responses. Also it is not slipping then. I think it just has air in the system
(Post 334578)
It sounds like normal hydraulic clutch engagement to me.
There is the little adjuster to adjust how far out the lever is but that's about it. As stated above it does sound normal. If it did have air in the system you have to have it pulled all the way in before it's dissengage.
Don't waste your time bleeding. I bled through 2 bottles of brake fluid with no positive results. From what I understand, these bikes don't engage until almost all the way out.
Originally Posted by herbvtr1000f
(Post 334567)
By no means is a properly working clutch MC / slave cyl difficult to use on this bike or a cause of "bike jolts like it is slipping", that's just user control. The SH clutch MC / Slave can be a bit difficult with air in the line, and or contaminates in the slave cylinder.. that cause erratic engagement. Disassembling the MC and slave, cleaning well with new fluid, reassembling and bleeding air gets you a great feel, very controllable clutch system. |
I checked the flue and it was nasty. Almost like it had water in it. I used my friends airbleeder and put new fluid in it. As far as where it is engaging of is likeyou said right at the start of the lever being pulled. I guess I just need to get used to it.
(Post 334753)
