Choke Slips?
Hi all. I have a 98, and when I pull the choke out, it generally slips back in, sometimes within 5 seconds, sometimes within a couple minutes - to *almost* all the way back in. It's kinda nice cause I never "forget" and leave my choke on, but then again, I'm also screwed if I want to drive a few blocks with it on.
Anyone heard of this? Also, how does one "balance" the chokes? Thanks! ________ Honda RC100 |
Pull back the rubber boot (behind the knob) and tighten the knurled nut.
This ought to be a sticky. |
Or just moved to the technical info one. Torque specs, wiring diagrams, and yes the common problems. The few things I found in there were a huge help and already had me spending a few hours "under" the bike. :-)
BTW - what's idle supposed to be set at on this bike? Before my latest service it had to be like 1500, now it seems like it'd idle at 750 rpm all day. I need to set it, balance the carbs, reset it, then check my TPS again. -Abe. ________ Jeep Cherokee (Xj) Specifications |
1100-1200 stock spec.
If you have problems with clutch in stalling, bump it up to 1300-1400 Forget the TPS. |
| All times are GMT -7. The time now is 08:38 AM. |
