Choke Slips?
Old Sep 15, 2005 | 09:28 AM
AbeFM's Avatar
AbeFM
Choke Slips?
Hi all. I have a 98, and when I pull the choke out, it generally slips back in, sometimes within 5 seconds, sometimes within a couple minutes - to *almost* all the way back in. It's kinda nice cause I never "forget" and leave my choke on, but then again, I'm also screwed if I want to drive a few blocks with it on.
Anyone heard of this?
Also, how does one "balance" the chokes?
Thanks!
________
Honda RC100
Old Sep 15, 2005 | 10:03 AM
jschmidt's Avatar
jschmidt
Pull back the rubber boot (behind the ****) and tighten the knurled nut.
This ought to be a sticky.
Old Sep 15, 2005 | 10:08 AM
AbeFM's Avatar
AbeFM
Or just moved to the technical info one. Torque specs, wiring diagrams, and yes the common problems. The few things I found in there were a huge help and already had me spending a few hours "under" the bike. :-)
BTW - what's idle supposed to be set at on this bike? Before my latest service it had to be like 1500, now it seems like it'd idle at 750 rpm all day. I need to set it, balance the carbs, reset it, then check my TPS again.
-Abe.
________
Jeep Cherokee (Xj) Specifications
Old Sep 15, 2005 | 10:25 AM
jschmidt's Avatar
jschmidt
1100-1200 stock spec.
If you have problems with clutch in stalling, bump it up to 1300-1400
Forget the TPS.
Livefreeordie89
May 27, 2013 09:23 PM
Anto
Sep 11, 2007 12:14 AM
Pookbe
Apr 25, 2007 11:12 PM
lovemyhawk
Mar 27, 2007 01:00 PM
vtwinlover
Feb 4, 2007 03:52 PM
