choke broke, what part #?
Does anyone know the ronayers part # for the choke pieces that seem to always break when you remove the carbs? Cant seem to find it in the fiche.
I think that you have to buy the valve set to get the SE valve nut:
Part Number: 16046-MBB-640 You can also order a brass one from a polaris scrambler. This worked for me pretty well... I had to drill some threads out I think to get it to work, but it doesn't break now! Don't remember if I needed to drill the threads out or not, actually, I just remember messing around with it a bit lol! It's polaris SKU #3130199 As seen in this thread: https://www.superhawkforum.com/forum...lve-nut-17450/ |
Wtf put down the hammer when your working on the bike.
I don't even use tools on my bike... just fingernails and teeth to take all the bolts off. It takes some practice to break a tire bead by squeezing it with your hands but it's totally doable. When you do it this way, the inevitable valve nut breaks or triple tree gets bent from pressing too hard... so you just gotta replace it with a new one and move on, being more careful of your own strength the next time around...
lol |
Yeah, I was careful enuff during the motor swap but finally busted it while putting the choke knob back through the frame.
OK so where to get the part and how much? |
