SuperHawk Forum
-   -   CCT Replacement (https://www.superhawkforum.com/forums/technical-discussion-28/cct-replacement-18616/)
REDVTR1000 May 8, 2009 05:11 AM
CCT Replacement
Oil changes, air filters, brake jobs, these are all things i can do no problem. When it comes to CCT's i am a little over my head. If i were to buy some APE CCT's and brought them to a shop what am i looking at price wise? with all the horror stories here i figure i should probably get this done.
SlowHAWK May 8, 2009 06:11 AM
Best bet would be to have them put in when the valve are due for service/checking... as the labor for adding the CCT's in when doing the valves should be minimal.
J.
Little_Horse May 8, 2009 07:32 AM
If the shop is resonable that as, but never hurts to ask, I would say it should not be more than an extra hour of labor
REDVTR1000 May 8, 2009 08:32 AM
i had the valves done 2000mi ago so that is out. they said the CCT's were fine but i would be replacing them as a piece of mind thing
Otto Man May 8, 2009 03:23 PM
What is your past mechanical expeirence? They are really not that hard to replace. In fact, to me, getting to them was the hardest part. Replacing them once I was there was cake.
lazn May 8, 2009 04:13 PM
Just don't skip the step of getting the engine to TDC and you shouldn't have problems.. (it'll probably take a few hours on your own though)
But if you pay to have it done, I would guess around an hours labor + parts
Circuit_Burner May 8, 2009 06:47 PM
To give you a $$ idea( shops vary city to city but are usually the about the same on price within each city )
At my shop we would charge you 3 hours on cam chain tensioner, 4 hours for valve adjustment, and if you gave us the CCT to install during the valve adjustment, it would be free.
Labor is $95.00 an hour, about par for dallas area honda shops.
