Carb sync, book calls for a 20mm Hg difference
Title says it all, My question is why is it recommended to set the vacuum even if the book calls for a 20 mm Hg difference? Is it that its too small to worry about or :confused: Thanks for the input!
That is a MAX difference and only then when using the factory gauge set.
Ideally, you want them the same. |
Thank you for the clarification.
