SuperHawk Forum
-   -   Carb Sync (https://www.superhawkforum.com/forums/technical-discussion-28/carb-sync-25280/)
1down5up Apr 19, 2011 01:53 AM
Carb Sync
Hi Guys,
When syncing the carbs is the adjustment screw/bolt located on the left hand side of the bike, infront of the rear cylinder facing forward?
If so, how the hell do you get in there. I can just get in there with an extention, a knuckle and a 7mm but its a pain in the ass.
Is there an easier way?
jay956 Apr 19, 2011 02:59 AM
thats the way i do it, doesnt seem hard to me...
1down5up Apr 19, 2011 03:23 AM
i find the thermostat is in the way
comedo Apr 19, 2011 07:04 AM
I use a 1/4" drive extension, universal joint, 7 mm. socket and a good flashlight. I wrap the joint with a layer of electrical tape so the socket doesn't flop around as much. A Phillips head screw driver with a flexible shaft works too. The job gets easier with practice.
fred Apr 19, 2011 06:08 PM
i've got a Motion Pro 90deg carb tool i picked up a long time ago for mucho bucks. i was using it with a 7mm socket the other day to sync my carbs. as i was squirming around, i managed to knock off the socket with the MP drive end. i spent a good hour with multiple flashlights trying to locate those precious items. good thing. in the process i noticed that i'd not placed the carb cooling hose clamp that sends coolant from the thermostat, and the hose end was weeping coolant.
remove tank, airbox, front cowl, unseat carbs. what fun. i found the MP end and socket down in between the cylinders. [man! it just started raining monsoon-style here!]
Hawkrider Apr 20, 2011 03:10 PM
There's a picture of it on my website. If I can get a pic of it with the tank on you sure as hell can get to it with a 7mm socket and an extension!
RWhisen Apr 20, 2011 04:02 PM
I had no trouble getting to it with a 7mm offset wrench.
dutchdude Apr 20, 2011 04:15 PM
Thanks for asking the question - i was looking at mine the other day and thinking the same thing. well i guess i have to stop thinking about now and just do it.
WordTooYoMamma May 28, 2012 05:05 PM
I just started the bike and stopped it several times to tweek the adjustment, each time I would turn the rear throttle adjustment clockwise so I could access the bolt, made my adjustments with a spanner wrench.
E.Marquez May 28, 2012 07:11 PM
1/4" drive driver handle (screw driver type) 3" extension, 1/4" drive U joint (wrap one layer of light tape around the u joint so it does not flop all the way over), 7mm socket. makes the task VERY easy.
kum1ankka Jun 8, 2012 03:40 PM
I'm still in process of getting to syncing the carbs when I stumbled upon this thread. Have any of you guys tried if something like this works?
Flexible Driver for Hose Clamps - 10" (7mm Hex, ABA)
A flexible hose clamp driver with 7mm head if the link doesn't work or goes dead...
E.Marquez Jun 8, 2012 05:49 PM
1 Attachment(s)
Kind of, but with existing tools.
Attachment 24606
Craftsmen 1//4" stuff
7mm socket
2" extension
2" flex drive extension
1/4 drive driver handle
all but the flex drive come in even the most basic Craftsmen 1/4" drive set.
8541Hawk Jun 8, 2012 06:18 PM
I personally don't like the flex drives as they tend to "wind up" and then turn to far.
Also lifting the rear of the tank slightly makes the adjustment much easier.
E.Marquez Jun 8, 2012 06:36 PM
True if using them for a fastener that is tight, but on the carb screw that only takes a ftlb or 2 to turn it's a non issue.. or at least is with the tools I use.
I also use a 1/4 drive U joint with a wrap of electrical tape to limit "flop".
Both setups work well for me.
