Carb shim mod.
I performed the carb shim mod tonight on my bike its basically stock with baffelectomy shimmed it out to .060 and put back together. First thing i noticed after syncing carbs and taking it our for a spin was i cant keep the friggin front on the ground(sweet)and im 6'7" 270 lbs even tucked into the tank it takes almost nothing to get the front end 36 " of the ground.
I was way happy with the mod. but it appears i lost some midrange power under hard acceleration has any one else done this mod with same results? and btw pair is removed. |
Mine seemed to run better with the mod but I believe I only went .026 on the brass washers I bought. You might be running a bit rich with .060 but if you're happy with it leave it be.
Originally Posted by RickB
(Post 131783)
Well i think you may be right i was just going by this post from the Admin from about a year ago i found
(Post 91583)
The stock needles don't have a circlip. It's just a head, like a nail, with a washer under it. The additional washers go under the head, in other words slide the washers down the needle. With bafflectomized pipes you will want to add several washers, for a total of 0.060". Just to clarify: There is a retaining dealio in the slide with a threaded hole in it. You take one of the bowl screw and pull that plastic retainer out. Then the needle and washer will come out. Add washers. Spray little o-ring on the retainer with some WD-40 or something and reassemble.
looks like a perfect time to tear it down again. |
Originally Posted by filter69
(Post 131808)
ill try out .040 if i can keep the low end torque and get a bit of mid without to much work(money) that will be perfect. raining today so looks like a perfect time to tear it down again. |
Along with the tps mod, this is the best bang for the buck. $1 at radio shack if you don't all ready have some.
(Post 131825)
As always YMMV. :cool: |
Hmm, Sioux Falls, SD is 1400 ft above sea level. This mod is intended for sea level. Try pulling out one washer.
1 Attachment(s)
(Post 131831)
(Post 131831)
Ok im a Tool i went to pull a shim and realized i didnt put my velocity stacks on (duh). Slapped them on and it went nuts pulls hard though
2.8k to 8k no problem. Now i can pull the front up in second gear with no clutch even. but just to be sure i pulled it down to .040 and lost alot of bottom end torque so put it back to .060 runs great now i can pull a wheelie for about 1.5 blocks now no problem smooth power. i guess for anyone reading this with a stock bike and baffleectomy and your looking for some power shim your needles. Now i just wish i could buy a can of High Compression Pistons and just pour em in :). that will be this winter Thanks for all the help guys. |
I've done that before but usually I find the stacks right after I button up the air box- I've never got to the point of running it without them. Glad to hear you got it sorted out
Originally Posted by 8541Hawk
(Post 131836)
You're getting slow there Greg - beat ya to it again Attachment 1230
a) You didn't look up the elevation for Sioux Falls, and b) I just had to run and help out my roommate with an overheating car. Oh, and c) :nana: :mrgreen: |
(Post 131867)
Sure, but
Would someone mind giving me some dimensions on this shim/washer that you guys use to do this please? I understand the varying thickness, but a maximum O.D. and minimum I.D. would be appreciated. I haven't gotten into my carbs yet and i'd like to find something to have ready, rather than have to search for.
PATIA! |
What type of difference would this mod have compared to swapping the stock slow jet 45's for 48's? What about the extra work involved?
I've done a bunch of work on my bikes, like putting in gold valves and checking valve clearances, but I've never torn carbs apart. Like slim, I'm trying to get an idea of what I'd be getting into. |
Originally Posted by Slim
(Post 132612)
They are a #4 washer from the Home Depot. Any #4 washer should do, you might be able to find thinner/thicker variations though. (Smaller than 1/8" (I think) they call the bolts/nuts/washers by #: ie #8, #4.) |
Originally Posted by Scooberhawk
(Post 132782)
I've done a bunch of work on my bikes, like putting in gold valves and checking valve clearances, but I've never torn carbs apart. Like slim, I'm trying to get an idea of what I'd be getting into. As for difficulty, if you are mechanically inclined at all, it's not hard. Take your fuel tank off, air box out, loosen the carbs and pop the black covers off. Careful of the 11" spring (stock). Use one of the cover screws to pull the plunger out of the slide assembly, and don't lose the small stock washer on the needle. Put your washer(s) in and reassemble. The spring can be tricky, but if you hold your tongue just right you'll get it in no time ;) The first time I pulled the covers, I took the carbs all the way off. Since then I pulled out one washer and did the rear carb without taking the carbs off, and I just pulled the carbs out of the boots to get at the front one. |
Originally Posted by Syclone
(Post 132786)
The ones I've got measure .312" OD, .127" ID, and .030" thick.
(Post 132788)
Not sure on the main jets difference, but I think the washers affect the A/F through more of the throttle range.
(Post 132788)
(Post 132790)
The trick to installing the spring is to compress the spring on the shaft of a screw driver and then you can put the compressed spring into the cover. Then hold the slide up with your finger through the throat of the carb and pop the spring into the slide and install the cover.
