Bucking Hawk
Just got a 98 hawk with the magic 31k miles on it!!!!!:)
It bucks often under 3k at a steady speed...:mad: I fear its the CCTS and this sucks!!!:eek: What do you all think it could be?:confused: I know people talk about changing at this milage with the manual APE? CCTS. What is the cost from the dealer to have this done? Thanks! Ken |
Do you by chance think the bucking sensation is actually a back fire into the air box?
mine does the same thing... before and after I adjusted my manual CCT's as well as checking valves. I juct chocked it up to one of those quirks. the only thing I havent done yet it sync carbs... so if you do and it goes away let me know. I just downshift and ride up around 4grand
Originally Posted by Thumper
(Post 175186)
If its only below 3k rpm, mine has been doing that since it was new...driveline surge. These bikes run pretty lean at idle and low rpm with stock carb settings. An ignition misfire is more likely under load.
Try downshifting to bring the rpm's up. If the bucking goes away don't worry about it, or have the carbs looked at if it bothers you. Mine runs flawlessly over 3k. Paso Robles? You've got some great roads up there. What are you running under 3k rpm for?:rolleyes: |
Could be a few different things but I think most likely improperly set up carbs.
Don't see how it could be CCTs. CCTs serve only one purpose- to keep the cam chains on. If they're on ( and everything else is OK) the bike runs fine. If they're off it doesn't run at all. |
You are lean. This is common if you have slip on exhaust and have not rejetted.
Mine will do it as well. It seems to do it more when it's colder outside and I going slowly through town. It's always done it, I was told it was due to the motor running too lean at the lower rpm's. It goes away at the higher speeds.
It's nothing to worry about. It's one of the many quarks of owning a Superhawk. |
It sounds like a lean and possibly needing a carb sync.
It's not a "quirk". You need to rejet and sync the carbs. Do it and your bike will run great!
Originally Posted by jbaxx
(Post 175229)
Mine never does this, Jardines, K$N, Factory Pro Jet kit dialed in correctly for my bike and elevation |
(Post 175232)
+1
Mine never does this, Jardines, K$N, Factory Pro Jet kit dialed in correctly for my bike and elevation Some tuning can remove this problem. My bike does not do it now. |
Okay I feel much much better! I just bought it used so I dont know if it did it from day one. It has yoshi pipes and rejetted from the previous owner.
THANKS AGAIN! Ken |
do you have a full tankż haha
Get some seafoam in the tank and see if it clears up. I bought mine wrecked and had been sitting for a year and a half or so. I fgured it was the carbs so put about a half a cans worth of seafoam in the gas about two tanks worth and it runs like a champ ever since! I've got her up to just shy of 160mph without a stutter or hesitation...
Originally Posted by shayne
(Post 175271)
+2
Some tuning can remove this problem. My bike does not do it now. Mine did this when I got it, but I've since adjusted carbs. |
your problem could be slack in the cam chain like you mentioned. i dont have a twin but 954. but a lot oof my bikes lurching went away with the ape. there is slack in the drive chain which always causes a little buck. slack in the cam chain will do it too (even just a bit)
the combination of 1 to 2 inches of slack in your drive chain plus an improperly slacked cam chain (worn out honda tensioner). can definitely cause some extra yankage
If you have a dynojet kit drop the needle clip one notch lower, if you have a stocker shim the needle (pull the needle away from the seat) It will stop to fart in the intake
Well I guess I will find out soon enough.
I think the CCT went last week. I am going to build a platform to pull the front head off and see what damage there is. See my other post about either breaking the chain or cct in the front cylinder. |
