Brake Master Part ID
1 Attachment(s)
What is it?
This came out of the reservoir from a 03 954. It was under the rubber anti cavitation piece. I don't think it is suppose to be in there with the rubber piece as it was distorting the rubber. Looks like it is ment to perform the asme function, but.... Attachment 19921 |
That is meant to be in there, described in the parts fiche as "Float". From the top down you should have the cap, white plastic diaphragm plate, the rubber diaphragm, then the float. Not unusual for the diaphragm to be distorted this happens when the fluid level is sucked down.
(Post 396245)
The fich shows the diaphragm as the same on multiple yrs/models, but the float isn't used on all the same yrs/models. I'm guessing detail changes in sub parts. |
