SuperHawk Forum
-   -   brake lights not working (https://www.superhawkforum.com/forums/technical-discussion-28/brake-lights-not-working-22880/)
Ar-Nail-D Jun 13, 2010 08:25 AM
Hello Everyone
I'm an European (Italian living in Paris, France) 1997 superhawk/firestorm owner.
I'm just putting my lady back for duty after some sleeping and had t change the regulator and the stator along with other parts.
Now the only problem left is that the brake lights refuse to go on when i brake! (standard lights are ok)
Bulbs seem ok, the breaker too...
Any ideas/advice?
Thank you in advance!
A.
residentg Jun 13, 2010 11:59 AM
try replacing the bulbs anyway, it is not always easy to tell visually if they are blown(or use and ohm meter to test). Then check fuses and then connections, and last switches.
