Brake and clutch levers
Can anyone tell me if there is any other Honda model (cbr 600, 900, or 954) that the clutch and brake levers matches the 03 superhawk?
Thanks... |
According to the Honda Fiche, good luck on the hydraulic clutch lever, but you have a lot of brake lever options:
Where Used Tool |
Ronayers.com Microfiche Honda>Motorcycle>1999>VTR1000F>FRONT BRAKE MASTER CYLINDER 05
Try putting the front brake and clutch lever part # into the 'Where Use' search box and all will be revealed.... |
I may be wrong but I think they are pretty much all the same. The master cylinder bores are different but the basic levers are fairly standard.
My bad I hadn't seen the new posts. |
Edit: Mis-post
Clutch lever looks identical to the VFR lever.
Saw an anniversary edition VFR 800 at the coffee shop this morning. Looked identical. |
Originally Posted by matt365
(Post 341749)
(Post 341750)
Thats because it's the same part number :p
lol. That'll do it. |
