Bike height
Can someone with a good handling VTR take a measurement from the ground to the bottom of the crankcase?
I think my bike is very tall compared to most. I have the triples somewhat high on the tubes and a Penske with 2 spacers at the top. I want a baseline height for when I do a fork swap and know some standard to go by. Also a measurement to the bottom of the lower triple would help too, or some point that could be compared. Thanks to anyone who can do this odd request. |
The bike sitting on the stand, measuring on the left side, I have 9,5'' from ground to the oïl pan/crank case seam or joint if you prefer. Once again taken from the left side, from ground to bottom of triple tree, I have 26''.
I may not be the perfect example since I run 900RR front end, with a custom made triple tree. However, we will be speaking of mm in différences from stock to my setup. So this should get you started pretty close. |
