Basket case hawk help me sort it out
98 hawk all seems stock except d&d slip on and dj jet kit i bought the bike a few weeks ago not running. Last tagged in 2011 so I'm sure it's been down a while. First inspection harness had been chewed into at the igniter and cdi box. Rat squirrel who knows but was chewed completely into. Ordered used harness used ignitor used cdi new rr while waiting checked valves cleaned carbs changed all oil/antifreeze. Noticed missing tps sensor installed harness with original ig/cdi fired up bike idles ok front cylinder only runs with choke and rear carb leaking gas thru float valve today re cleaned carbs rebuilt petcock as it had a drip tested and working after rebuild. New iridium plugs front runs a little better but not consistent rear no longer leaking. Still wont rev up vac line connected to petcock correctly carbs are spotless. Any ideas as why it won't rev up. Slides are free diaphragms are good Kicker when starting it will rev up for 1/2 seconds then just idles dies of throttle turned any. Have another set of carbs on there way with tps sensor ordered 2x coils and pulse generator today |
I believe TPS must be connected to control ECU or it won't run. I just fired mine up and disconnected the TPS. It idled, but that is all it would do.
Have one on the way to try. But even in factory service manual it says to unhook tps rev to 3500 plug up and speed should increase. One of there ways to test the tps mine won't even get to 2000 rpm |
