annoying backfire through carburetors
I've mentioned in other posts that my hawk has an annoying little stumble/backfire through the carburetors at about 3500 to 4000rpm in 1st and 2nd gear. I've pulled the filter and air box to look for anything that might be causing the issue. I checked for kinked fuel lines, kinked vent hose, kinked vacuum hose. No joy! I've not touched the air mixture screws so I didn't mess with that. The petcock is on all the way and I didn't find any air leaks, (I have removed PAIR equipment and installed block off plates). The stumble is more obvious when engine is cold. Recently, I ran the fuel all the way down, filled up and the stumble seems to have vanished. (I have gotten into the habit of topping off due to the small tank size and fear of running out of gas). While checking everything I discovered a small amount of fuel in the vacuum hoses installed to make balancing easier.
Is it normal for there to be a little fuel in the vacuum lines used for balancing? Both of mine have it. I understand the line coming from the fuel tank diaphragm that I "T"d into might have fuel in it but they both do. Do I have a problem? :squid: |
Not sure if that conditions normal or not, but my carb balancing lines have that too... I realized this when the caps I used to close the lines rotted due to not being fuel-resistant like the lines themselves were. So the caps rotted, and I was getting vacuum leak there on the ends of both lines. Switched to bolts with clamps on the ends and that stopped that.
Good luck... backfires suck and they scare the shit out of my girl when she was riding on back, lol. |
Carb farts are a part of the personality of the Superhawk I believe the majority of carb farts are caused by bad tuning. My bike suffered with these quite bad when I first got it. I found they disappeared after adjusting my TPS which also got rid of the idle speed fluctuating. I then gave the carbs a strip down clean and re-adjusted the mixture (fuel) screws and synced (balanced) them up. Everything has been fine since and the only time when I ever have them now is after messing around (experimenting) with my carbs and it generally comes back if my needle height is slightly lean. Iv'e never had gas in my vacuum lines. That's a new one on me, not heard of that before. (:-}) |
Usually, if you get gas in that line, it's a sign that the petcock is on it's way out... But yeah, on occasion, you'd get it anyways...
It is hard to diagnose over the 'net.
Is it a "cough" (lean) or a "fart" (rich)? If I had to guess I would say the needles need to be raised slightly ( 1 shim) and you have a lean cough situation as that is the RPM range when you just start coming onto the needles. |
Originally Posted by 8541Hawk
(Post 347184)
Is it a "cough" (lean) or a "fart" (rich)? If I had to guess I would say the needles need to be raised slightly ( 1 shim) and you have a lean cough situation as that is the RPM range when you just start coming onto the needles. if shimming the needles, would it be to both or one? |
After reading another post I am pondering the idea of me not having the sync exact. I thought I had it but maybe it's worth looking at again.
Is it a CA bike and did you also remove the evap stuff?
Just asking because if you did there should be 3 fittings on the carbs that should be plugged. |
(Post 347225)
Just asking because if you did there should be 3 fittings on the carbs that should be plugged. The balance screw takes a little getting used to because if I use any pressure to turn the screw, it affects the rpm and the settings won't be correct. Difficult little bugger to set, IMO. |
(Post 347321)
I use a 1/4" drive socket, u-joint, and 12" extension. Once the socket is seated on the screw, a light touch will prevent upsetting the idle speed. I forget what size the screw head is, 6 - 8 mm.
(Post 347323)
So close on the size......7mm is the winner but that set up is how I also adjust mine ;)
Thank you all again for the great advice! |
