F4i temp sensor wiring
Old 11-25-2018, 05:06 PM
hampton64's Avatar
hampton64 is on a distinguished road
So I converted my gauge cluster to an f4i set up. My temp is off about 170 degrees. I have searched to find how to wire up the 3 wire f4i temp sensor into the 2 wire super chicken. I'm hoping 7moore7 or someone else who has done this can shed some light on this for me.
cheers
Brandon
hampton64 is offline
Old 11-26-2018, 06:53 AM
Id find a 3 wire sensor that will fit the SH over the other option.
E.Marquez is offline
Old 11-26-2018, 07:10 AM
7moore7 has his VTR up for sale so if you hope to catch his attention, I'd send a PM. Not on here much anymoore. lol
Progress looks good hampton. Keep us posted.
Wolverine is offline
Old 11-26-2018, 05:25 PM
hampton64's Avatar
not sure what you mean by this? The f4i sensor fits in the hole I think... the electrical connection is a 3 wire on f4i and 2 wire on sh.
basically just need to know how to wire it.
Old 11-26-2018, 07:18 PM
I did this with the 600RR dash. I recall needing the temp sensor from the donor bike. (I think that's what you did). I can look in my mech notebook to see how I did it but since its resistance based it should be spot on with the new sensor. You'd have to look at the wiring diagrams of each to see what each wire carries.
smokinjoe73 is offline
Old 11-27-2018, 03:39 AM
hampton64's Avatar
Looking at the schematic for each I think the 3rd wire on the f4i goes to the tps... so do I just leave that lead shrink wrapped out of the connector or ground it?
Old 11-27-2018, 04:35 AM
I cant picture grounding it. I will look later but I think you just cover the wire. I thought mine only had 1 wire so you ground the other.
You have the donor bike sensor and harness plug?
Old 11-27-2018, 06:03 AM
Try it open... safest bet..And Id bet that works just fine.
If it does work as you think it will, snip the wire and seal it off.
Sdustin
05-14-2016 07:52 PM
superbeater
06-08-2013 11:01 PM
swaptrex
08-11-2010 09:50 PM
fishface
05-03-2008 08:49 PM
Verne
03-11-2008 02:19 PM
Quick Reply: F4i temp sensor wiring
