SuperHawk Forum
-   -   Adjusting gearlever (https://www.superhawkforum.com/forums/technical-discussion-28/adjusting-gearlever-14087/)
Silverstorm Mar 20, 2008 11:05 AM
Adjusting gearlever
I just changed my ckutchplates this week and mounted everything again. But now my clutch releases very late. I mean, I have to squeeze the lever more than half way before the clutch releases and I want it to release right at the start of the squeeze. Anyone an idea how to adjust?
Thanks
Hawkrider Mar 20, 2008 08:41 PM
You might have air in the clutch hydraulic system. Try bleeding the clutch.
bdizzle Mar 20, 2008 09:52 PM
+1
Silverstorm Mar 21, 2008 12:00 PM
Thx fot the reply, but the problem is solved. I'd push back the puching rod to far. I've opened up its belly again, pulled it a bit. Put it bach to gether a pulled a wheelie to see if everything held together.:D
It did, allthoug it's was quite slippery in the rain!:cool:
