99 runs awful after tuneup, help me help my mechanic.
So I took my 99 (18,780 miles) into the shop and had some work done, now my hawk struggles to start, bogs down while riding, wants to idle 5-600rpm, and in general runs like doo doo. Prior to being in the shop it ran perfectly, and the mechanic and I are both stretching our head trying to figure out what we did that might have screwed that up.
I am not a mechanic at all so I need help to diagnose this so I figure I will list off the things that I had done, and hopefully one of y'all will take pity on me and tell me either what I should check here in my garage or what I should tell the mechanic when he gets it back. New air filter, OEM spec hi-flow brand Factory Petcock rebuild kit installed (what started this) New ngk dpr9eix-9 5545 spark plugs installed in place of evx Clutch and brake fluids drained refilled and bled. Bike is full of fresh no alcohol gasoline. I have previously put ape manual CCT. It's never had any other engine work or carb work done on it in fact that was the original air filter and spark plugs that came in the bike. I have not done a pair removal on this bike, the bubbling and popping never really bothered me. So, a word about my mechanic he's super honest and very talented but his primary focus is dirt bikes now and ducati's earlier, so it's not specifically familiar with this bike. The only actual Honda dealer near me is utterly useless so I go to this guy. I'd like to be able to give him a list of specific things to check, unless there's somebody on this forum in Central Illinois that could possibly help me a little more directly, lol. So thank you ahead of time for your assistance. |
Nothing there that sounds like it should create such a problem. May have been something done during the work that is totally unrelated. Disconnected, redirected, crimped....
vacuum line?
Yeah I talked to the mechanic after I got home and we're both pretty stumped, unless one of the spark plug wires broke or something.
Oh I think I forgot to mention that we also changed my spit tank and did a flush and fill on the coolant, but when I test wrote it I didn't even get it warm enough to activate that. I was also going to pull up the picture of the petcock install and make sure that all of the hoses were connected up correctly. Any other suggestions of things out there have him check? |
Originally Posted by barrysuperhawk
(Post 414760)
Originally Posted by xeris
(Post 414785)
The vacuum line to the petcock? Wouldn't be the first time that it was installed wrong.
Glad ya got it figured out. Those lines are a major contributor to issues.
(Post 414756)
Lad go riding - Put a dry bag behind you & run away from home for a year. If my math skillz be correct - thats less than 1k a year....Lord Have Mercy. |
(Post 414836)
Wait you have a 23 yr old VTR with less than 20k?
(Post 414836)
Lad go riding - Put a dry bag behind you & run away from home for a year. If my math skillz be correct - thats less than 1k a year....Lord Have Mercy. This '02 in Miami only has 600 (that's HUNDRED) miles lol... |
I've got a few more miles on one of my 98s...
