98 VTR1000 Not charging
Old May 24, 2023 | 06:49 PM
domjmartin's Avatar
domjmartin is on a distinguished road
Question 98 VTR1000 Not charging
Battery will not hold a charge. Replaced the battery, replaced the r/r with one out of a random older CBR. Had to cut wires to fit new connector for r/r and current r/r now has a higher OHM resistance than previous, battery will now MAINTAIN around 13+ at idle, which it wouldn't do previously, but any revving will decrease voltage, letting off throttle will bring voltage back up to 13+, so as stated the stator and r/r seem to be maintaining the battery, but not charging it while driving. All 3 stator wires at r/r connector read power coming from stator so I'm avoiding the fact that it could technically still be a stator issue. AC power coming from stator wires into r/r connector also drops when revving, which could be from the r/r ohm resistance but electric is not my strong suit. Any help is appreciated. If needed, where could I find a semi-cheap but reliable stator and gasket, as all the gaskets seem to be paper so therefore non-reusable. Bike appears to have no other issues, but anything helps.
Old May 27, 2023 | 04:31 AM
Used many stator's and R/R's from Ricks over the years when I worked at a shop. I'd not hesitate to recommend them to anyone. The factory service manual is a free download in the knowledgebase section if you need it. Should definitely not be going down with revs.
https://ricksmotorsportelectrics.com/index.php
Cyberputo75
Apr 21, 2017 08:53 PM
Chefmatt
Mar 30, 2016 09:04 PM
hardrider40
Jul 7, 2012 10:10 AM
lazn
May 2, 2011 10:21 AM
RI-redhawk
Apr 24, 2009 11:42 AM
