2001 regulator with cooling fins
Have you expercienced failures with the newiest regulator (since 2001 with cooling fins ) ?
My 2001 VTRis about 26000 kms, one battery replacement last year. Do you think I should fit a cooling fan on it ? Or is this "new" regulator more reliable ? I would prefer mod it or replace it by a reliable one instead of taking the risk of a ECU unit fail or other electrical problems .... :roll: |
Re: 2001 regulator with cooling fins
I replaced my failed stock regulator at the beginning of last summer and hadn't had a problem since. I've roughly ridden about 7,000 miles since the replacement. I did scrape the paint off the sub frame under the regulator and apply some heat sink compound to aid heat transfer to the sub frame. A lot of the day's I have ridden have been over 95 degrees. I think the new one is a lot more robust.
Don't use another Honda unit! I haven't heard anything good about them yet. Use an R1 unit. They are cheap on ebay and a much better design.
Here are 2 guides, one by a member on this forum. Guide 1 Guide 2 with stator replacement as well |
i also found this one on ebay...regulator
But this one is half the price
If I'm not mistaken I believe the R1 regulator that's used in superb pages that Mithrandir refered to here are from '99 '00 '01. These are the same part number and are all 5 wire regulators. I'm not sure but I think the regs from later years have been changed. The Yamaha part# is 4JH-81960-01-00 ('99 - '01) and the 'new' price is only about $60. Even though I picked up a used one for $30 the $60 price for a new one is a great deal compared to Honda's alternative.
True. But newer ones also work. The second link was to one using an '03 regulator.
I am debating this mod as a preventative measure. Any opinions on that? |
Originally Posted by penst8grad";p="
(Post 6922)
Aye, if you've got an older bike, then preventative maintenance is a good idea. I've been left stranded once before by a failure (VFR400, not the VTR).
I don't have much experience with the post 2001 bikes. My XX, which is an 02 and is the first of the XXs with a redesigned r/r now has 32K miles on it and not a hint of a problem. However, it is a monstrous item compared to the pics of the new VTR item, so I can't really give you any assurances either way. I'm putting together a VTR streetfighter right now and will be using an R1 unit. I've personally changed about a dozen bikes over and I'm aware of around 50-odd VTR/VFR/XX's that have done the mod and never heard of any troubles since then. |
What's the indicators that the rr may be failing? My signals are slow to respond, especially when it's cold out. Could that be an indication that it's about to go? Also I replaced my battery because it gave me trouble starting. This was back when it was colder out.
My failed R/R became evident by the smoke pouring out of my rear fender! Most likely oil from a blister on the R/R that was burning on the frame. I had no other electrical symptoms. I replaced mine with the OEM part which now has cooling fins and seems beefier. We'll see what happens.
john2kvtr have a look earlier in the thread where I've posted a link to one of my articles about it. There's some very simple clues such as browning leads.
