SuperHawk Forum
-   -   2000 VTR Turn signal switches have a long delay (https://www.superhawkforum.com/forums/technical-discussion-28/2000-vtr-turn-signal-switches-have-long-delay-27617/)
geekonamotorcycle Feb 22, 2012 08:49 PM
Hello,
My turn signal switches move poorly with some resistance and when I set them left or right it can sometimes take up to a minute for them to come on. Additionally when I disengage them I sometimes see an occasional flash from the indicators in the cockpit.
I want to know if anyone here has disassembled the controller and cleaned it up with any success? if so did you take any pictures? Any pointers?
rz_racer_69 Feb 22, 2012 09:50 PM
Yes. They are known to be problematic when gunked up. Do a search for "slow turn signal" on this forum. Cleaning them helps some times, and some times the relay needs replacing.
smokinjoe73 Feb 22, 2012 09:53 PM
Geek, didn't you see the giant thread on this like last week? Pay attention man!
aja Feb 23, 2012 10:31 AM
Pull apart the switch, clean it up, grease it, put it back together, but upgraded auto relay, problem solved.
7moore7 Feb 23, 2012 10:32 AM
Yep, thread etiquette. This was all JUST discussed.
jte4200 Feb 23, 2012 11:00 AM
https://www.superhawkforum.com/forum...-relays-27559/
rz_racer_69 Feb 23, 2012 11:29 AM
What sort of blinker fluid works with the IC relays? Do I need synthetic?
Bandit400man Feb 23, 2012 12:11 PM
Haha, naw, dino works!
7moore7 Feb 23, 2012 12:27 PM
Yeah but you have to replace it more often!
aja Feb 23, 2012 02:45 PM
I've been using 100% canola. If I really feel like spending big bucks, ill get the already seasoned/used oil from Burger King so I smell like fries and onion rings. You could say my blinkers are biodegradeable friendly.
7moore7 Feb 23, 2012 03:10 PM
I just use sun/moon power. Secondary mirrors mounted right above the grips, and I flip them back and fourth on the side that I'll be turning on. Cars catch the glint of light and know exactly what I'm doing right away!
geekonamotorcycle Feb 23, 2012 06:39 PM
Lol sorry guys I have not been logging on and missed it. I will document my exploits as I do this and I will use canola oil for sure!
