2.0 radiator cap
i am looking for a usa based company to buy new radiator hoses and cap 2.0 for my super hawk and can not find any place on line i live in az queen creek and every shop i have called can only get a 1.1 i all ready have new radiators incoming
If you want stock parts (sorry I have no idea by what you mean with 2.0 and 1.1) then go to Partzilla and order up.
If you are referring to 2.0 bar opening pressure, then you must be planning on allowing the bike to run much hotter than stock, and I'm not sure why you would do that. A 1.1 bar cap will allow water/glycol to reach 270F/130C, which is into the red zone on the temperature gauge. |
i was told by a mechanic that i should look.for a radiator cap with 2.0 on it becuase i live in a very hot climit and it will help reduce my bike temp will decress the boiling point so now i am lost and yes the 2.0 means bars so please i have looked at the fourm here and found a few post but not sure what to make on this
The higher pressure cap won't keep the bike any cooler, it will just extend the upper temperature before localised boiling starts in the engine.
Without a decent radiator cap the coolant boils at 225F, and when that happens the coolant gets blown out of the reservoir tank. To keep the engine temp down, make sure you have a decently working cap, and that the radiator is clean and free of lots of kinked fins so the airflow is maximised. Some folk also add a manual override switch for the radiator fan so they can flick this on in traffic and start the cooling process earlier. |
well i am waiting for brand new radiators to put on and new hoses as well any idea on the switch placement and if there are any videos on how to do that. it is one of the thingd i want to do as well
The basic circuit for the radiator fan comes from the battery, through the fan motor then through the thermoswitch on the radiator and back to ground. So the fan always has a positive feed with the ignition on, it only activates when the thermoswitch closes at around 212F. If you splice a new cable into the lead that terminates at the female spade at the thermoswitch, then take your new cable and put a switch in it, then terminate to a good chassis ground you should have a manually switchable fan.
If you are getting the "racing" rads, you will need to make the cross tube longer. I used an aluminum pipe piece to do it. Also I don't remember if those rads took the same cap. They might but they sure don't accept the fan switch. You have to go fish for that. I posted on here where I found it. Its a totally different size than the stocker.
Also just get a new stock cap. Your old one cant be trusted so just replace it. It will help.
just got my new radiators in and apperently can not upload a pic from my phone my radiators are gpi racing www.gpiautoparts.com which comes with a new radiator cap
That was easy.
now i just need to replace all my radiator hoses lol
Why replace hoses? Did you get a fan switch with them?
mainly because i. want diffrent color so its more for look then any thing
Rad caps are rated at "Bar" or "LB" or both.
1.1 Bar (16 lbs) Cap 2.0 Bar (29 lbs) cap The VTR comes with a 1.1 bar cap We get about 2-3 degrees of temp increase before boil over for every psi increase of the cooling system.| So using a 1.1 bar cap we make the average boiling point of a stock cooling system somewhere closer to around 257-260 degrees. Using a 2.0 bar cap we make the average boiling point of a stock cooling system somewhere closer to around 270-299 degrees. The motor is not staying cooler, your just raising the boil over point....and of course the cooling system pressure. STANT brand makes a ton of Japanese rad caps, the Auto world has one that fits..I don't have the PN off hand. A re-branded Stant cap here http://www.ebay.com/itm/400985232182...466&rmvSB=true for $22 will get you that 2.0 bar cap EDIT I "think" it is the Stant 10363 Racing Radiator Cap - 28-32 lb. Load Capacity, but you need to confirm that |
