'04 with no spark.
Short story: no spark at plugs, checked: neutral safety switch and checks good, ignition switch and checks good, kill switch and checks good, and side stand switch and checks good.
Not so short story. Pull up to a stop light after a 60 mile stint and put it in gear let out the clutch and stall it upon take off. Restart and the clutch fully engages and about to open her up when she dies. Nothing. I can smell fuel out of the exhaust but can tell there is no spark. I tear into it and can not find a culprit. Any words of wisdom will be great. Glad to be back on US soil but too bad I didn't even akers it home on my first ride. Hahaha |
Also, I did check fuses.
RR status? You may be experiencing one of the many failure modes. How is battery voltage?
Clutch safety switch?
(Post 388417)
Originally Posted by AndyMX47
(Post 388435)
What do your plugs look like, if your running too rich and they are heavily carbon'd up you could have fouled out your plugs. Both fouling out at the same time is unlikely but not impossible...
Also have you tested your harness and made sure you have continuity where you want it and make sure there isnt any shorts. Are the coils getting the voltage they need? |
(Post 388523)
Also have you tested your harness and made sure you have continuity where you want it and make sure there isnt any shorts. Are the coils getting the voltage they need? I have not ran a continuity check on the harness as of yet but I am almost positive that the cois are not getting and voltage. I have not had time to dig further into it as of late but I will this friday. Thanks for your input scottiemann. I'll report back in the next couple of days. |
So, disconnected the connectors at each coil and put a test light on the pins to see what happens. Found that when the ignition switch initially switched to the "run" possision the L.E.D. in the test light gets power for about .5 of a second, then upon cranking nothing. So I imagine that the harness is good since I do get power briefly.
Pulled the clutch cover to take a look at the pulse generator. Upon removal a bolt fell out of the cover. It came off of the pulse generator. The other bolt was backed off by 1 full turn and my pulse generator contactor struck the rotor and bent it all to hell.
Dodged a bullet. I think I will one up Honda upon replacement and add some blue thread locker. |
Wow, didn't see that one coming. Those so rarely fail that I have heard of. Good job finding it.
(Post 388638)
I am very relieved that it was nothing too serious, just too bad the part will be here before I go back out. However it was fun to do some diagnostic work again. |
