Need help finding connector widder gloves
Morning
It is a propriety connector not going to find a direct replacement I think as it was not a main stream design.
IBA store leadership bought out the Widder inventory when they when widder went out of business.
https://ibaestore.com/index.php
They may have what you want...
After that, Id look at converting all to a standard SAE plug
I actually have a couple left over but instead of converting to SAE, I went to 2.1 mm coaxial connectors as used on most heated gear for at least a decade. Easier to connect even in the dark and more efficient (less resistance)...
But not everyone needs that advantage, and so 2.1 mm coaxial connectors is a outstanding suggestion
