Another better mouse trap
I like the idea. Not sure about actual use.
Quiet Ride Helmets Noise Reduction Helmets |
if its only up to 19 decibels, I'd still be wearing ear plugs.
Interesting idea though. |
Radical rear-access Vozz Helmet could make motorcycles far safer | Daily Mail Online
This seems like a great idea. Probably would help with wind buffeting and sound quite a bit. |
Ah yes. Rear access....ohlala !
quiet rider... good idea and would likely work. my first concern would be comfort
vozz... interesting. most noise is the booming on the bottom of the helmet. if this helmet fits closer to the neck, maybe it will minimize the booming. |
Talked to the friend of mine that gave me the link to the Quiet Helmet site and he has the retro kit on order. I'll report back on the details when it happens. He has a spare that will be the test helmet. Good for me as I don't want to muck up my only. This will help me decide if I want to go this route.
Originally Posted by xeris
(Post 392472)
I will get to see it Sunday and that will give me a better idea of it's worth. |
(Post 392472)
(Post 392427)
i have tested the booming noise at the bottom of my helmet. i simply placed my hand over that area between the helmet and my neck and poof, booming noise gone
that helmet skirt you linked to... it looks like it would work but does it raise other issues like restricting movement or retaining heat? i have long wondered why the helmet manus are not addressing this problem. it seems to me that it would be a simple fix |
(Post 392670)
that helmet skirt you linked to... it looks like it would work but does it raise other issues like restricting movement or retaining heat? i have long wondered why the helmet manus are not addressing this problem. it seems to me that it would be a simple fix I agree, seems like a simple problem to address, not sure why there are no simple solutions though. |
(Post 392670)
what i have wonder is why the manus don't simply bring the helmet foam down farther below the helmet onto the neck. instead of a sharp angle from the edge straight across to your neck, it could go on more of an angle downward to the neck.
another idea might be to try an inflatable bladder around the bottom of the helmet we put a man on the moon. there must be a solution for this |
| All times are GMT -7. The time now is 07:13 AM. |
