Snap rings are from the devil!
Spent 2 hours today trying to get the snap ring out of the clutch master cylinder. Good god I have had bad experiences with snap rings before but that was rediculous.
I honestly think ant company that puts a snap ring in to hold parts stable should be kicked in the nuts. There are so many other viable options then snap rings. I get it. They area cheap but come on! Think of the poor mechanics that have to deal with them! |
Internal Circlip pliers?
The way the ring was positioned the pliers we're not long enough to reach the ring. Tried straight, 45 and 90 degree. Eventually had to destroy the ring with a screw driver and pull it. Had a replacement clip with the rebuild kit.
Keep in mind I am doing this at my girls place where the bike is broken down. It's a 30 minute drive to get to my tool box at the house and another 30 minutes back to the bike. I've got it put back together working on bleeding the system but waiting patiently as I try to clear all the air out of the master cylinder hahaha. |
Originally Posted by Meier Link
(Post 387846)
I honestly think ant company that puts a snap ring in to hold parts stable should be kicked in the nuts. There are so many other viable options then snap rings. I get it. They area cheap but come on! Think of the poor mechanics that have to deal with them! Yes, it can be a pain for the at home wrench.. but that is not the fault of the OEM. And none of that makes it any better for the guy in his garage trying to figure out how to get the snap ring out. |
Best option I don't think so. I work primarily in aviation and snap rings are used on disposable parts. Which are one and 1 thousand. Set screws and threaded linkages are more of slut viable option to me .
When I am 30 miles from home and a snap ring that is oriented wrong holds me from fixing a problem that a 11\32nd or metric equivalent could fix me up faster as an option kills any kind of love for a snap ring. |
(Post 387874)
When I am 30 miles from home and a snap ring that is oriented wrong holds me from fixing a problem that a 11\32nd or metric equivalent could fix me up faster as an option kills any kind of love for a snap ring. I think with an honest look, it will be clear what an Automotive and powersport standard ...the snap ring was chosen for the task. I agree they can be sometimes frustrating to remove or place in position.. and so many types, not just internal and external, but styles of those as well. I have a 36" wide drawer filled with snap ring pliers so I have the right tool for the job. And that's only what is needed for powersports, automotive and light truck (plus light -med duty powered equipment) Second what do you do in the aviation industry? Sounds like your all set to build an outstanding SuperHawk.... |
(Post 387846)
Glad ya got it out. :cool: |
Second what do you do in the aviation industry? Sounds like your all set to build an outstanding SuperHawk.... I have a slew of snap ring pliers at the house down fall was the bike was broken down not at my house. |
(Post 387887)
If you had had the common sense and forethought to have broken down in your garage, Meier, then this would have been a non-issue. I think we're done here.
And welcome. |
Originally Posted by VTR1000F
(Post 387891)
And welcome. Henceforth, in the best interests of the forum, you should change your post-script to include snap ring pliers along with tires and oil as verboten subject matter. |
Now your making me rethink my proposal to my girlfriend with a snap ring...
(Post 387899)
Not quite done.
(Post 387906)
(Post 387907)
Best interest of the forum? Shit. Like anybody's been following my rules up to now.
| All times are GMT -7. The time now is 06:35 AM. |
