Why front swap paper closed?
Here are MY stats
Owner installer Redman onto 98vtr forks, triples, wheel, discs...2002 954 fender RC51 bars ? fully adjustable clipons from a Ducati wreck went with 2004 600RR 11/16ths brake mc for it's integral reservoir RC51 calipers...the bigger ones all ballz tapered rollers I had to custom grind a lot off the bottom triple stops to get lock to lock....it's easy with a dremel as it's alloy. Moved rads back 3/4" so that bottom triple doesn't squash upper connecting hose. Put a few carefully chosen washers under key lock mounting screws and it fits fine and the steering lock works fine. Get some thin stainless washers and look carefully and do it, it's easy. Haven't installed the fairing yet so I'm hoping there are no clearance issues. total cost of all parts around $850 |
Originally Posted by redman
(Post 139968)
Here are MY stats
Owner installer Redman onto 98vtr forks, triples, wheel, discs...2002 954 fender RC51 bars ? fully adjustable clipons from a Ducati wreck went with 2004 600RR 11/16ths brake mc for it's integral reservoir RC51 calipers...the bigger ones all ballz tapered rollers I had to custom grind a lot off the bottom triple stops to get lock to lock....it's easy with a dremel as it's alloy. Moved rads back 3/4" so that bottom triple doesn't squash upper connecting hose. Put a few carefully chosen washers under key lock mounting screws and it fits fine and the steering lock works fine. Get some thin stainless washers and look carefully and do it, it's easy. Haven't installed the fairing yet so I'm hoping there are no clearance issues. total cost of all parts around $850 Why closed? Because it is a tech paper,, Not really a thread for user comments.. Just a place to find a clean thread with information. No weeding though hundreds of posts to fid the info. If there was a way in this forum software to always keep the tech info at the top of the thread, and the comments below, it would be open.. But for now the better solution is, read the white paper, and if you want more specific info, PM the user. If you want to discuss it, you can start a thread in the General or Mod forum. Thanks |
(Post 139968)
TXS sent you a pm with updates and final config for the paper!
