Tear down, mod, and rebuild
Been a while since I've been on here so just thought I'd share what I am doing to the VTR this winter. Performance upgrades are going to be: Hi comp pistons, port the heads and Flo bench them, header back exhaust, carb rebuild and tune, cam swap, lighten the flywheel, ARP hardware, and ignition advance.
Cosmetic work is going to be keyless ignition, race fairings, paint, digital cluster, and color match the rims fork lowers and accent stripe. Hoping to have it done by spring. Just to think I was going to just do the valve adjustments becuase I'm at 15,980mi but now I got her pulled all the way apart. Lol |
4 Attachment(s)
Progress pics:
Thanks for the heads-up, Squid. I'll make a note to block out one season when valve adjust time rolls around.
Hey Squid, what is the intermatic timer timing? Inquiring minds want to know.
How much do you think you will have in materials?
Originally Posted by VTR1000F
(Post 399752)
Originally Posted by xeris
(Post 399753)
Originally Posted by sabermammoth
(Post 399756)
I'm interested in doing a keyless ignition on mine too and linking it to my Nissan keyless fob so I only need one key fob for both - it shouldn't be too difficult to get the ids sent and all and the actual wiring should be quite simple... But are there kits or are you making it from scratch?
| All times are GMT -7. The time now is 06:10 AM. |
