Stock Chain Question...
I am always asking questions and you guys are always there to help me! lol. I need to know how to tell the difference between a stock chain and a different one. Reason I ask, is I got my superhawk and the front sprocket was switched to a 15t and I want to buy a 16t or stock one, doesnt matter. and I want to make sure I buy the right one. I can take plenty of pics jsut let me know what you need and if you could educate me, I will listen! Thanks guys!
Not sure that I understand why it matters about the chain being stock or aftermarket. However, if you don't see a master link, then you probably have the original. I know that my 98 still does.
When you install the 16t sprocket you may find that you need a bigger chain, unless yours has enough slack to compensate. If you need a bigger chain, buy an aftermarket such as DID or RK. Hope that helps! |
Mine came stock with a top of the line DID... ZVM530... something or other.
Ok so all sprockets will fit the same chains? some chains are just better? I understand that some may need to be bigger, I think I have plenty of slack, just trying to work both angles for gas mileage and performance, and right now I need the mileage, I dont think a 16t sprocket will help a ton, but every little bit counts!
Originally Posted by handkaudio
(Post 173335)
If you want to change sprockets and/or chains they have to be the same size. In the VTR's case, your choice is either 520 or 530. A much bigger rear sprocket will require a longer chain with more links than stock to compensate for the larger circumference. |
OEM chain is 102 links.
Most chains have there pitch (520,525.530...) stamped on one of links. You should check this to make sure some one has not put a conversion kit on the bike. Once you know that just order your sprocket. You may or may not need to order a new chain depending on how mush slack you have.
Originally Posted by FTMS
(Post 173398)
A 520 pitch chain requires 520 sprockets, front and rear. You can't use a 520 chain with 530 sprockets and vicy versy.:D 520 chains are lighter, so they conceivably give a very slight performance advantage, but I doubt you would even notice it. 520 chains and sprockets are cheaper than 530, but they wear faster.
Stock chain and sprockets are 530. Chain should be 102 links. |
Cool, thanks one more time guys!
